Multiple cursor or multiple plots?
I have generated an XY graph with an array of 10 points. Great.
I pulled the peak value out and made a cursor appear at that point. Great.
I now need 2 more cursors or indetification marks on the graph as well as a integral calculation.
This is called aFull Width at Half Max (FWHM) calculation.
We get the peak/2 on the Y axis and draw a line across the graph.
We then find the 2 intersecting point on the graph
Once we know these intersecting points we integrate what is inside the area.
See attached photo.
We would integrate from X1 to X2 and fmax.
24060i6D4A1D8C095ED187 So my question is what is the best way to visually represent this data?
I can't seem to add 4 cursors and get them where I want them.
Message 1 of 13
(5,171 Views)
DO you have some data for me to play with?
Tim
GHSP
Message 2 of 13
(5,165 Views)
Here's the vi
I'm close
Message 3 of 13
(5,156 Views)
Something like this? I find the peak and the peak/2 points then use the threshold vi to find the x value and then look to see when it falls below the peak/2 point for the x2 value and plot all of the cursors.
24064i50175883EA9746F0
Tim
GHSP
Message 4 of 13
(5,151 Views)
@Murph wrote:
Here's the vi
I'm close
You did not save any data in your vi. I made my own. It shoudl give you a good example of how to do everything.
Tim
GHSP
Message 5 of 13
(5,150 Views)
Thanks.
I changed a few things using your suggestions but still need some data that I don't know how to get.
In your example on cursor X1 you found the Y values by peak/2. Good.
Then using the threshold peak detector you extracted a value for X.
I tried that but do not get what I expect.
So close. What am I missing here?
I am using an XY graph and yours is a waveform graph, does that make a difference?
I put the data in this vi.
Message 6 of 13
(5,135 Views)
OK I made a few more changes to your code and now I have it working on the XY graph. It make it slightly more complicated. I would say that you need more resolution in your graph or you will need to interpolate the data if you need the value when the line cross the cursor position. Look at the graph and you will see what I mean.
24126i67933035788756B2
Tim
GHSP
Message 7 of 13
(5,126 Views)
Are you using Ver 10?
I can't open that vi.
I am still using 2009
Message 8 of 13
(5,122 Views)
Here is version 9
Tim
GHSP
Message 9 of 13
(5,117 Views)
I agree that if we use more data we'll be more accurate but the way we are getting the X scale value is based on a fixed data point. If the attached example it is the 4th array element.
What I need is the calculated exact value ofthe X scale where it intersects with the 50% of peak.
24322iE153E35384FCB67724324i9359E0AF4BC83D2E
Message 10 of 13
(5,077 Views)
