11-29-2011 10:20 PM
Kindly suggest me that how to show 3 analog signals in same graph & it should be continously running.
i have tried but i could not find success however same thing i have implemented by chart.
Kindly suggest me by an example vi.
Thanks & Regards,
Vipin Ahuja
11-29-2011 10:33 PM
You would want to use waveform chart and not graph. Post your current code for more help.
11-29-2011 11:11 PM
11-29-2011 11:16 PM
11-30-2011 01:09 AM
To support with Dennie, here is the vi. Have a look at this, probably this might help you to carry on with your work.
11-30-2011 02:50 AM
Thanks for your response.
This vi has almost resolved my problem except that i want graph's time axis should move ahead & backward data deleted as new data comes like 10-20 seconds data shown in graph & then if 20-30 sec data comes it should automatically delete 10-20 sec graph data & should show 20-30 seconds graph and similarly it is going on.
Can you suggest how to do it?
11-30-2011 03:14 AM
This is just example and one of my old VI. It resembles to your project.
Or
try and make a search on forum as "multiple plot" and see where does it end.
Hope this may helps you.
12-01-2011 12:02 AM
Hi
Check this out probably this is the one u asked i think....
12-01-2011 04:13 AM
No, i want graph should move like a chart with every second updation.
Why i choosen graph then because i want a horizontal cusror which is not available in chart.
So i want this type of graph with horizontal cursor.
