Multiple Y-Axis Scales
Okay, I have a graph that I will need up to 3 different Y-axis scales. I see how to add multiple scales manually, but I dont always want all 3 scales to be visible. Is there a way to use the property node to turn on or off the extra Y-axis scales?
(3,147 Views)
Yes, you have first to select the axis (active scale)you want to turn on or off, then make it visible or not.
There is something in the example below.
Do not swap axis, because there is a problem with right hand scales disappearing below the graph pane...
(LV bug ?)
Chilly Charly    (aka CC)
(3,147 Views)
Thanks! That did it.
(3,147 Views)
