Multiple Visa Ressource name
I have a chemical system with several pH probes, connected via USB to my computer. I have already designed my program to display the pH, using VISA functions.
I would like to avoid repeating the program for each probe, so for each com port.
How can I write my program only once, so that it can be done for all COM ports?
Attached is my completed VI.
Thank you in advance.
(1,411 Views)
Hi nicos,
Create a subVI and connect the VISA reference as input to the ConnPane…
Suggestions:
  • Don't initialize the COM port with each iteration!
  • Don't use BytesAtPort, there are most often better ways
  • Handle each device in its own loop - or use one loop to read all COM ports…
(1,385 Views)
On top of what GerdW said:
The first thing you need to do is watch this video: VIWeek 2020/Proper way to communicate over serial
Next let's think about your program architecture. One Big Loop is never a proper program architecture, I suggest a simple State Machine to start with.
Use a Cluster to hold your VISA sessions and open each Com port using a For Loop ONCE at the beginning of your program
Then later in your program you can read all the instruments sequentially using a For Loop
Don't forget to close your VISA sessions at the end of your program
=== Engineer Ambiguously ===
(1,362 Views)
