Multiple Synchronized Output
I have a PXI-6259 card and am using Labview.
I need some advice on the best method of achieving the following requirements:
Drive four pneumatic valve units, each has four solenoid valves. two to apply air and two to vent air.
There are 2 apply profiles and two vent profile - this is for an extended life test
So for one unit the sequence is:
  1. Apply profile 1 on sol valve 1 and apply profile 2 on sol valve 2
  2. Vent profile 1 on sol valve 1 and vent profile 2 on sol valve 2
  3. Apply profile 2 on sol valve 1 and apply profile 1 on sol valve 2
  4. Vent profile 2 on sol valve 1 and vent profile 1 on sol valve 2
  5. Sample the output every 100th operation (or some arbitrary number)
  6. Repeat
I am ok with the above and have put together some rudimentary VIs to load a profile then drive a DIO pin and sample the output - I've attached these.
I would implement the above using a state machine.
I have the interfacing hardware from a previous project
The reason I require some help is that we would like to run four units in parallel with different profile and with offset start times and I am in need of some advice about achieving this
Thanks for any guidance that can be offered.
Dave
(2,896 Views)
Hi Dave,
What do you mean by offset start times? Are you setting a single test to run and then automatically want the other tests to run after that or are you setting this application to run at a specific time then walking away and leaving it to its own devices.
It sounds like you need a central controller which is scheduling when the tests need to run and then running them as needed, similar to a queued state machine where you set each of the four units into an idle state, and then send instructions by a queue from a "Master" controller loop to run the tests as needed. It looks like in terms of getting started you have all of the DAQ code you need, now I believe it is more on the architecture side of things.
There is a good article on our website covering the queued state machine, and goes through some the basics and a high level overview of the architecture:
https://decibel.ni.com/content/docs/DOC-32964
Let me know what you think of this and if you have any questions feel free to reply.
Best Regards,
James Kent
James Kent | Applications Engineer | National Instruments UK & Ireland
w: uk.ni.com | ireland.ni.com
(2,843 Views)
Hi James,
Thanks for your reply; I am back on this project now following some delays.
I am struggling with the queued state machine archeture and could use some further guidance please.
Here is a more concise list of requirements:
  • 4 UUTs (pneumatic valves A, B, C and D); each UUT has 4 solenoid vales (2 inlet and 2 vent)
  • There are 2 profiles (charging and venting) to be applied; the profiles are 20sec in duration
  • So Valve A and B run profile 1 and valve C and D profile 2
  • Valve A starts at T=0
  • Valve B starts at T=2sec
  • Valve C starts at T=5sec
  • Valve B starts at T=7sec
  • When each valve finishes its 20 sec profile it will start its profile again
I have attached a spreadsheet overview of the profile which shows a single shot.
Thanks for any advice you can offer.
Dave
(2,762 Views)
