Multiple Slide Bar cursors
I have got the following issue with a Multiple Slide Bar.vi ie. my 4th cursor (the red one symbolized by a vertical bar) will erase the orange (2d cursor) and green (3d cursor) area that are supposed to remain fixed during the whole execution. I am clueless as to how to solve this. The purpose of the VI is to have 3 fixed area (blue, orange, green) and a moving red cursor moving across the area.
Thanks a lot for your suggestions,
Christophe
Message 1 of 9
(4,318 Views)
Hi Christophe
If i were designing this I would cheat slightly. I would use two sliders one on top of the other with the top one invisible. They can reasnobaly easily been syncronized and read too.
have a look at the attched VI. will this approach work for you in your larger application?
best regards
Graham Green
Software Product Marketing
NI | Emerson
Message 2 of 9
(4,307 Views)
Graham,
Sorry could you please repost in Labview 8.2?
Christophe
Message 3 of 9
(4,302 Views)
Hi - yup, back another version for you.
best regards
Graham Green
NI | Emerson
Message 4 of 9
(4,298 Views)
Hello Christophe,
I've slightly modified your VI (see attachment). I simply switch the fill-color of the 4th slider depending on its position.
Maybe this works for you...
Thomas
Message 5 of 9
(4,294 Views)
Thomas,
Could you please repost in LV8.2?
Thanks a lot,
Christophe
Message 6 of 9
(4,290 Views)
the priviously postet VI saved for LV8.2...
Thomas
Message 7 of 9
(4,287 Views)
Thomas and Graham,
Thanks a lot for your help. Each of your solutions has its own merits (either lighter code or lighter front panel)!
Nevertheless I do not understand why I cannot reach the same result by configuring the 4th cursor in a "No Fill" mode to have it 'floating over' the 3 others.
Christophe
Message Edited by Christ0phe on 09-25-2008 03:15 AM
Message 8 of 9
(4,236 Views)
Hello Christophe,
the problem is not the "NoFill" of the 4th cursor, but the  "FillToValueBellow" of the other cursors. As soon as the 4th sliders value is higher than the 1st one, the 2nd slider will fill to the value of the 4th. This makes your colors change.
Thomas
Message 9 of 9
(4,209 Views)
