Multiple Graphs
Ok i have hit a bit of a snag,
I have essentially three seperate graphs, each displayed individually. What i woudl like to do is to change the x-axis (time in my case) Programatically... so if i set the time to 5000 all the x axis changes to 5000.... The problem is i can do that using property nodes!, but am unable to do that whilst experiment is running!!, i thought of including a scroll bar common to all three?? but need help... i wnat a way so that i can change x axis for all graphs simultaneously... whilst vi is running...
all helps GREATELY appreciated...
Mansoor
(3,052 Views)
Using property nodes is the way to do it. Why are you unable to do it with the program running? Can you post an example of your code?
(3,035 Views)
 ok if there ever was a dimwitted fool that woudl be me... i just looked at my programme as was about to reply... when i noticed that i had not put the property command in the loop, so obviously it was not going to update 😞
alas... i feel silly now!!
Mansoor
(3,018 Views)
