Multicolumn does not show any value when I tried to put a value on column 4 or above
When I put a value in column 4 or above ( in any row ) multicolumn listbox doesn't show me any return. I got a example from NI forums and changed it to see if it works , but the results are the same.
Does anyone know about it. I'm using labview 2009 9.0f3
Thanks in advance
(2,380 Views)
Can you link to the example you are using?
What is a "return" that it does not show? I am not familiar with these terms.
Why don't you attach a simplified version of your VI with steps to demonstrate the problem
(2,368 Views)
