Multi-turn Encoder Problem
I have been handed an encoder that was knocking around and the brief is to incorporate it into a new multi-turn test rig. The problem is that it is only a single turn device.
Has anyone written any code that reliably latches the turn count on a single turn encoder when the output rolls over?
The application is quite slow (24 RPM), the interface to the encoder is all working so I just have to handle the number stream.
Thanks in advance!
(2,833 Views)
Accepted by topic author ssk
Now solved!
(2,798 Views)
