Multi trace XY plots
Basically i have the same question mentioned here: http://forums.ni.com/t5/LabVIEW/Labview-to-Excel-or-word-howto-do-multi-trace-XY-plots/m-p/487561/hi...
I do have two 2d arrays, one representing all the X-values, the other representing the Y-values. How can i plot a graph and export to Microsoft Word with the Office report generation toolkit?
In Excel its a piece of cake:
(3,339 Views)
Are you wanting to plot the data in LV? Graphs have a method for exporting images of themselves.
If you are plotting in Excel, setup ranges that the excel plot expects data to be in. When you insert the data into excel, the plot will update to show them.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,335 Views)
Mike, thanks for you reply!
I want to create a graph in a MS Word report with the "office report generation toolkit", see the VI.
(3,310 Views)
Yes, but where do you was to do the graphing? MS Word doesn't graph data.
Mike...
LabVIEW Champion
(3,307 Views)
Generating XY-plot with multiple X-series is not possible with the Report Generation toolkit.
The toolkit uses Microsoft Chart to generate the graph and MSChart does not offer the possibility to do that.
So, as mikeporter already told you, the easiest way you have is probably to use a template Excel sheet properly set up for your graph and use the Report Generation toolkit to fill the template with data.
Cédric | NI Belgium
(3,243 Views)
