Multi-threading in LabVIEW
How does LabVIEW support multithreading?  I have written a program which contains multiple parallel while loops which seem to execute simultaneously.  I believe this is analogous to multithreading in Java or C++.
I would like to better understand the following:
1.  Do I have control over thread priority and processor affinity per thread?
2.  What is the scheduling algorithm and can I change it?
Chris
Chris Reyerson
Optical Systems Engineer
Arete Associates
Tucson, AZ
(3,262 Views)
If you're looking for the same level of control that you have in C, then you won't find it LabVIEW since LabVIEW automatically handles a lot of it. This link should be able to provide you with some general information: Multitasking in LabVIEW
(3,245 Views)
