(Multi^n)plot Waveform Graphs
I'm using LabView 8.2 and I need a waveform graph with twenty waveforms overlayed onto it (actually two waveforms taken ten times each, if that matters--but no, I can't just average them).  Using Build Array to make a standard multiplot with the Express Waveform Graph doesn't work, however, apparently because the express VI can only handle two waveforms at once.
Suggestions?
(4,380 Views)
Hi DJDDA,
when the Express vi doesn't work don't use it! Smiley Wink
Just use the way that is shown in the context help of a waveform graph indicator: simply build an array of plots...
Message Edited by GerdW on 06-20-2009 05:59 PM
(4,362 Views)
I've been trying to build an array of plots, I just don't seem to know how.
I am attaching a (very) quick & dirty nonfunctional program that may help demonstrate what I am trying to do; I don't think I'm explaining it well.
(4,328 Views)
Accepted by topic author DJDDA
Hi DJDDA,
right-click that last "build array" before the graph and select "concatenate inputs" Smiley Wink
(4,326 Views)
Perfect, thank you.
(4,306 Views)
