Multi-function synch AI read Dig Chan
When I try to run this example VI I keep getting an error (200077) telling me that I must use handshake, or On Demand Timing. I want to sych the two inputs so I need to use the sample clock implemented in the example. I am running version 7.1, and I have a 6025E.
Scott Donahue
University Of Illinois Urbana-Champaign
(3,271 Views)
When you select a VI in the example finder, you'll see a window in the lower right that explains which devices can run the software. For this example, your board is not listed because the digital I/O is not hardware clocked. M series boards have this feature but the E series (6025) only has software timing.
(3,261 Views)
Can you recommend to me a board that is digitally hardware clocked just like the analog input. I need something with at least 15 analog inputs and 20 digital inputs.
thanks
Scott
Message Edited by sdonah2 on 09-08-2005 12:23 PM
(3,252 Views)
There's the 6224, 6229, 6254, 6259, 6284, 6289. They all have 32 analog in and 32 clocked DIO.
(3,246 Views)
