Multi-channel logging with different triggers and looped 3-minute data acquisition cycles
Hi everyone,
I’m a beginner in LabVIEW and currently working on a project involving concrete mix testing. We're using a DAQ to acquire analog signals from two devices: a non-contact ultrasonic sensor and a Pundit tester.
Here’s what I want to do:
  • Each time we acquire 2000 samples, that’s one complete signal.
  • We repeat this process 100 times, ending up with a matrix of 2000 rows × 100 columns (each column = one signal).
  • I want to average these 100 signals row-wise, resulting in a single signal of 2000 averaged points.
    • This is similar to how the Average function in Signal Express works.
  • Then, this whole process (acquire + average) should repeat every 3 minutes.
    • For example, if the first acquisition starts at 12:05, the next cycle should start at 12:08, regardless of how fast the averaging finishes.
I’ve attached a vi file I'm working with for clarity.
Since I’m new to LabVIEW, I’m having a hard time implementing this. Any help, VI examples, or guidance would be very much appreciated!
Thanks in advance!
(299 Views)
Why and how do these "2000" samples denote a complete signal?
Of course, you can create a 3-minute cycled capture, but I want to ensure you're doing things right if there is an additional reason why the number 2000
Santhosh
Soliton Technologies
(268 Views)
"The most important part of this signal occurs between 320 and 600 µs, and 2,000 samples are sufficient to capture it. So:"
  1. "How can the time averaging feature of SignalExpress be implemented in LabVIEW?"
  2. "How can a 3-minute loop be implemented?"
(232 Views)
@wndulwlsp wrote:
Hi everyone,
If you only have 1 DAQ, then you need to combine the AI acquisitions into a single task or perform the tasks serially.
  1. "How can a 3-minute loop be implemented?"
Your VI has no loops, so you need to add one. You would use a while loop. The while loop can exit when the user exits the program or an elapsed time is reached. I recommend a state machine.
Add your waveforms together that you acquire and divide by the number of acquisitions. Use a shift register on your while loop to keep track of the sum.
You would average your waveform insteadYou would average your waveform instead
(219 Views)
