Multi Digital Input and Digital Output DAQ
Hello,In my project I would like to use a DAQ card which can read digital inputs and digital outputs at a time.At present iam having NI PCI 6071E DAQ card which can read digital inputs or digital outputs,but not both at a time.Please let me know whether there is one available with this feature.iN MY PROJECT I have to simulataneously read digital inputs and send digital outputs.
(2,631 Views)
I found the attached example for simultaenuous DIO, with the possibillity to change the line direction, for E-series devices.
Hope that helps.
Unfortunately it is written in traditional daq but you should be able to program it in DAQmx, because it works similar.
(2,615 Views)
