Multi Channel USB
I would like to download data logs from 4 USB devices simultaneously using LabView. Does NI make a USB device similar to the 4 channel RS323 serial communication products? I have not been able to locate one.
Kevin
(2,398 Views)
Not that I have ever seen.
But does it have to be from NI?
There are lots of manufacturers out there.
Here is one device:  https://www.amazon.com/StarTech-ICUSB2324-RS232-Serial-Adapter/dp/B000YB0NQG
I've used Startech stuff before without issues.  But I'm not making any particular recommendations on any specific devices.
(2,391 Views)
We use these 8 port hubs in the lab and they work great.  We have had a couple ports die but I think that might have been due to the hardware plugged into them more than anything.  They show up in Windows as normal COM ports, and they even work plugged into a real-time cDAQ device running RT Linux without anything extra work.
(2,326 Views)
