Moving On-text/Off-text on a Boolean control
Does anyone know how to move the On-text or the 'Off state' text of a Boolean control to the bottom left-hand corner of the control?  For example - if you resize the control on the front panel to say 204X204 pixels then try to move the text to any other location but center.  I have tried to 'Justify' the text without success.  Thank you, John
Message 1 of 16
(5,791 Views)
I know! I know!
I guess you want me to tell you, huh?
Well, you have to customize the control. Right-Click, Advanced -> Customize. Then you can move the individual parts. Check the LabVIEW Help. It explains it.
Message 2 of 16
(5,790 Views)
To just move the text, right click on the control and select 'Release Text'.
Message 3 of 16
(5,784 Views)
Then what do you do?  I have tried both suggestions...  Customizing and Releasing the text.  Any attempt to move the text, justify it, or whatever, doesn't move it to another part of the control.  What am I missing here?
Message 4 of 16
(5,780 Views)
OK, now I'm confused. What do you mean move it to another part of the control?
Message 5 of 16
(5,778 Views)
I attached a Word document with screen-shot of what I am trying to do.  Thank you for you help and prompt reply!  John
Message 6 of 16
(5,774 Views)
Accepted by topic author Newton2this
After releasing the text, you simply have to select it and drag it to a new location. It might be easier if you turned off the auto-tool selection.
Message 7 of 16
(5,771 Views)
edit: Dennis beat me to it. The key is the selection tool.
Message 8 of 16
(5,770 Views)
Thank you!  Removing the auto-tool and customizing worked.  Well done! 😉
Message 9 of 16
(5,760 Views)
Also, a little tidbit. Fail...tidbit incorrect.
Message 10 of 16
(5,758 Views)
