Moving Indicators with Shift Arrow in LabView 8.20 has Problems
Hello LV Users or NI Apps.
I often use the Move Indicators and controls using the Shift Up or Shift Down keys (Shift-Arrow keys Moves selected objects several pixels at a time ) to rearrange my controls/indicators around my frontpanel.  When I select my indicators and move it up/down the indicators become off pitch and snap into some other grid point where I don't want it to go.
I've noticed this problem only when when the "Options"->"Alignment Grid"->"Enable panel grid alignment" option is enabled.
Is there a work around to this without disabling the above feature? Usually I push on the keyboard the "G" key to disable the auto grid alignment but I can't do that at the same time push the Shift Up / Down keys.
Thanks..
crazycliffy
- crazycliffy
(2,639 Views)
Duplicate post http://forums.ni.com/ni/board/message?board.id=170&message.id=238061
Andrew Alford
Production Test Engineering Technologist
Sustainable Energy Technologies
www.sustainableenergy.com
(2,628 Views)
