Movie with LabView
I made a movie in LabView by changing the data wired to an Intensity Graph.
Then I had to capture the each frame by Alt+PrintScreen keystrokes to make
a sequence of images for an AVI or MPEG files.
Is there any way to automate this process? Or is it possible to save the
front panel image in a data file without using Alt+PrintScreen?
Vladimir Nikolski.
(3,351 Views)
Assuming you are using a recent enough version of LV, yes there is.
LV 4.1 included VIs for getting the panel image in a 2D array of
pixels so they could be saved to BMP or whatever file type you like.
With LV5 and beyond, there is also a server method for getting the
image. Again, you can save it wherever and however you like.
Greg McKaskle
(3,351 Views)
You could also use an HyperCam program, witch do avi fom user selected
region and if it necessary commpres it to mpg.
best regards
Mikrobi
Greg McKaskle napisa³(a) w wiadomo�ci: <38E002FD.F5564039@austin.rr.com>...
Graph.
make
ou like.
>Greg McKaskle
(3,351 Views)
