Move location of disabled item
I have a edit box placed on the front panel to log text message. Depending on the status of a boolean button, the edit box appears and disappears (the button enables or disables the edit box when it is pushed).
After the first time I place the edit box in place, I am not able to see it on the front panel. I have to go back to the block diagram and find the icon, double click on it and the front panel will show a dashed rectangle representing the position of the edit box. How do I change the edit box size and location?
Ryan
(3,004 Views)
Accepted by topic author RyanWu
You need to find the control or indicator right click and change the status to Show Indicatior See picture.
Tim
GHSP
(2,999 Views)
Can you attach the code
(2,996 Views)
