I have what I believe to be a unique application where I need to draw a line on a graph which can be moved by simply clicking in predefined boxes attached to the line. Boxes above and below the line in the upper right and lower left will be used to rotate the line relative to the axes while boxes above and below the line at the center of the line will be used to adjust the position of the line at a given angle. The attached file shows an example of how the line should look from a similar project programmed in C.
As you might imagine, what I am trying to do is set a threshold line. Therefore, I need to be able to read the line position for use in thresholding.
I know that this can be accomplished in a roundabout way by placin
g a transparent picture control over the graph, but I was wondering if someone knew of a more robust way of doing this.
I am using LabVIEW 6.1 FDS.
