Move Function Fails with Error 5: File already open.
Would replacing the move with a copy during the process and, at the very end, deleting the top-level folder work for your use case?
Santhosh
Soliton Technologies
Message 11 of 13
(496 Views)
When I do that, the Delete fails with error 5.
Message 12 of 13
(466 Views)
I noticed that the description of the Application Builder functions is a bit murky:
Build:
Builds a build specification using the properties in memory that you configure when you right-click a build specification and select Properties. To use this VI, you previously configure the build specification using the Properties shortcut menu option.
Deploy:
Deploys the output of a build specification to a target. To use this VI, build the build specification using the Build VI.
Message 13 of 13
(451 Views)
