Mouse position on picture
I'm using a picture control with mouse down/mouse move event detection. With the "Mouse" property of picture control i can tell the relative position of mouse cursor on picture. My problem is that the picture control has scrollbars, and even clicks/moves on the scrollbars fire the events! Is there a practical way to tell if mouse is on scrollbars or on real picture?
Message 1 of 10
(6,349 Views)
Here's a quick example that :
- tests the width of the vertical scrollbar for the picture control
- continuously checks if the mouse is in the zone of the vertical scrollbar
- lets you show / hide the vertical scrollbar
Hope this helps
it's in LV2010, let me know if you need and older version.
Epictetus
Antoine Chalons
Message 2 of 10
(6,334 Views)
Is it possible for you to post this VI and then I can take a look at it?
Message 3 of 10
(6,332 Views)
Thank you, at the moment i have only LV 2009.
Sorry my app is not easy to post but to get the interesting part just place a picture control with visible toolbars, an event structure with a "mouse down" event, and you're there
Message 4 of 10
(6,327 Views)
here you go with 2009.
Epictetus
Antoine Chalons
Message 5 of 10
(6,322 Views)
Doesn't work when the image is scrolled horizontally; but i got the point, to "measure" the scrollbar you get picture size with scrollbar hidden and with scrollbar shown and then compute the difference
Message 6 of 10
(6,317 Views)
Yes, I left it for you to do the horizontal check, just to make sure you understand it Smiley Wink and also because I'm lazy Smiley Very Happy
Epictetus
Antoine Chalons
Message 7 of 10
(6,312 Views)
Accepted by topic author Snamprogetti
Ok, i found a much simpler solution. You don't need to "measure" the toolbars; the DrawAreaSize property of pictures returns the drawable area excluding toolbars. The attached snippet checks if you're on the scrollbars
Message 8 of 10
(6,291 Views)
ERRATA CORRIGE: using ">" with a cluster and "compare aggregates" compares only the first element... here is a correct version.
Also, you may want to check that mouse is not on the frame or the caption, so i added a "> 0"
Message 9 of 10
(6,259 Views)
best solution
Message 10 of 10
(4,425 Views)
