Mouse cursor not changing during execution
I am faced with a unique problem.During the execution of my exe, when I come to a certain panel, the mouse cursor does not change from the pointer to the action tool.I have to tab it once to get it to change to select anything on the front panel!!!! i am doing this as part of a big application and i dont want the customer to sit there clicking with the pointer toll and getting bewildered.How do i automatically change the cursor in the case this cannot be fixed?
Does anybody know why this happens? i checked the tabbing order and stuff in the vI.Cant see any problem there......
wld be a great to get some responses
thanks
anand
(2,796 Views)
Anand,
It sounds like "the certain point" of your application is not currently running (it is idle). If the VI is not running, then you can tab through the controls, otherwise it should work automatically. Make sure that you don't have the "suspend when called" option set in "vi properties" for the problematic sub VI.
(2,796 Views)
