Mouse Wheel Event / PlatMods Value for CTRL Key not working anymore
I use the mousewheel on a graph to zoom in/out on the graph.
I have then made it so that I can hold down SHIFT key down to zoom only the X-axes and the CTRL key to zoom only Y-axes.
It's work perfekt in my old Labview 2016, but the CTRL key not working in Labview 2023.
I think it is the new Labview Zoom feature that is conflicting with my code.
I have made a little simple example to show the problem.
(1,327 Views)
Accepted by topic author Discrusio
Yoiu can disable Zoom feature by placing the following line into LabVIEW.ini (located in the same folder with LabVIEW.exe)
Editor.Zoom.BlockDiagram.Enabled=False
Another two Zoom-related Options options are
Editor.Zoom.BlockDiagram.MinFactor=2
Editor.Zoom.BlockDiagram.MaxFactor=1
Disabling zoom should fix your issue, I guess.
(1,305 Views)
Many thanks 🙂
(1,296 Views)
I've filed Bug 2717959 for this issue.
Christina Rogers
Principal Product Owner, LabVIEW R&D
(1,228 Views)
