Motor control using Myrio with photo interrupter
Hello
I want to control the motor with Myrio and labview.
I read the RPM of the motor with a photo interrupter, and at this time I referred to the FPGA code.
And I want to control the speed of the motor with PWM through the PID control of the read RPM.
I put together many examples to form the code below.
However, it seems that FPGA code and PWM code cannot run at the same time.
(1,650 Views)
I think the FPGA and express VIs do not work together.
But I have to use PWM VI. Can anyone help?
(1,551 Views)
I'm pretty sure that the functions provided by the myRIO Software Toolkit and show up on the myRIO Palette (including the PWM VIs) basically "take over" the FPGA.  The Good News is that they appear to have their own FPGA routines that do basic functions quite readily, but if you want to do more sophisticated processing, possible with the FPGA, then you need to go "all FPGA" to do so.  We had this experience when we needed more than two SPI channels ...
(1,598 Views)
Thank you for your answer.
So, does that mean I need to move the PWM function to the FPGA?
Do you have any examples of the PWM signal generation function with FPGA?
I coded referring to the example below, but the motor does not work.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000015CPCSA2&l=en-US
(1,593 Views)
If I were trying to create an FPGA PWM signal, I think I'd write some "calling VIs" that live in the RT Target that houses the FPGA (say, a cRIO).  One would be a VI that simply sets a Boolean Control on the FPGA Front Panel to True (Run) or False (Stop), .  The other would be one where you set the PWM Frequency (in Hz, maximum, say, 500 kHz).  Here you "do the math" to create two U16s representing the "High" and "Low" times for the PWM waveform and send these numbers to the FPGA.  This keeps all of the math in the Host -- the FPGA just needs to deal with one Boolean and two U16.
So what does this look like?  As with everything in the FPGA, you start with a "Do Forever" While Loop (wire "T" to the Stop indicator).  You need a two-chamber Sequence Structure.  The first Sequence Structure has a "Wait" with the High time wired to it, and the "Run" Boolean wired to the input of your chosen Digital Output line.  The second Sequence Structure has another "Wait" with the Low time wired to it. And that's it!
I recommend initializing the three FPGA Controls, "Run", "High Time", and "Low Time" to "False", 500, and 500 (which configures a 1 kHz 50% Duty Cycle Pulse Train, but turned off, so nothing happens until you call "Run PWM" (on the Host) with Run set to True.  [I presume you know how to do this].  Notice that the Pulse Generator in the FPGA runs continuously, looping every High Time + Low Time microseconds (which you can change whenever you want, but should probably turn the Pulse Train "Off" before changing).  When it is turned On, the Digital Out goes High, then Low, but when turned Off, it goes Low, and then Low.  Make sense?
(1,563 Views)
