Morse encode into light
Hello, I'm trying to make a LiFi morse code project. I am having difficulty in translating the morse code data into on-off arguments using light. How can I go about this?
(73 Views)
Hi Hell,
  • Which "difficulties" do you encounter?
  • Do you really need to morse the results of a FFT operation? (Why not start with a simple "Hello World!" or "SOS"?)
  • Why is there encoding and decoding in parallel?
  • Why do you need to en-/decode twice?
  • Why don't you use subVIs, atleast one for "encode" and one for "decode"?
  • Why do you need to show names of nodes? (You should use the context help when you need to know the name of a node…)
Did you know we cannot edit/debug/run images in LabVIEW?
Why don't you attach REAL code?
(I prefer LabVIEW2019, there is a "Save for Previous" in the File menu.)
(43 Views)
