More timing in DAQs
Is there any VI, or other way to allow a program to keep track of time that
has elapsed since the beginning of the program execution? I contacted support
and they told me that the "count events and time" VI was for a 5V TTL signal.
I used that VI previously, but it has not worked as I hoped. Any help would
be appreciated.
(2,648 Views)
There is not really a VI to do this, but this might work well enough for
you. Use the Time & Dialog -> Tick Count vi when the program starts to
get the current time in milliseconds. Then, in a loop, read the Tick
count again, and subtract the starting time Tick Count and display the
difference (or tailor it to seconds, or whatever you need). This will
give you elapsed time.
Mark
In article <39883351@newsgroups.ni.com>,
that
support
signal.
ny
help would
> be appreciated.
Sent via Deja.com http://www.deja.com/
Before you buy.
(2,648 Views)
