More precision in Timestamps
I'm acquiring 2.5MS/s with a DAQmx card. That means that my timestamps must have more than ms precision... When I have ms precision I get around (I don't know if it's exactly that) 2500 samples with the same time (for example 2500 samples at 0,023s).
So, how can I get more precision in my timestamps? I read something about getting another counter channel and use it as timestamp, but I want to know if there's any other path for that? I'm already acquiring 8 channels and 'fighting' to save them, I didn't want to add one more channel. And I need timestamps for EACH channel, and not one for all of them...
Thanks for the help,
Rafael
(3,281 Views)
Timestamps have 64 bit for 1 second so the absolute accuracy is much greater, maybe it's just the reprsentation.
Where do you read the timestamp?
Ton
My LabVIEW Ideas
(3,279 Views)
I'm saving the file with Write to Measurement File and I read it offline in TDMS File Viewer and also in Matlab (with the matlab converter from this link)
(3,271 Views)
The TDMS FileViewer will only set the start of the axis and continue from there on, so it doesn't really show what's in the file.
Ton
My LabVIEW Ideas
(3,256 Views)
But then how can it show the timestamp for each sample? (with ms precision)
(3,253 Views)
I'm reformulating my question:
How can I see my data with microseconds timestamps (any function, ow any 'path' for that), knowing that I can see it now in TDMS File Viewer with miliseconds timestamps?
(3,232 Views)
