Monitoring a TCP connection
Hello folks,
I have a VI that monitors a TCP connection using the function "Not a
Number/Path/Refnum". When the peer (the other side which this VI is
connected is a win program in Visual Basic) closes the connection, my
VI seems unable to detect the closed connection, it is "thinking" that
the TCP refnum is still valid.
How I can handle it?
Thanks!
(3,036 Views)
Hi giseli,
how did you check it? Normally you get an error if the connection fails. Can you upload your vi?
Mike
Message Edited by MikeS81 on 05-18-2008 08:50 PM
(3,035 Views)
Monitor the error cluster instead of the refnum. th refnum is a local handle that has nothing to do with the actual link. It's just a pointer to the link object. The error cluster holds the information you want to monitor.
André (CLA, CLED)
(3,002 Views)
Specifically, you will probably want to see when you get error code 66, " The network connection was closed by the peer".
(2,989 Views)
