Monitoring All Alarms
I am just getting started with my first DSC application.  The application I'm building requires the monitoring of hundreds of alarms.
Looking at the DSC functions, I see there is a ReadAlarms.vi that takes a shared variables array as an input.  I am able to implement this function, but it requires me to select each one of my shared variables explicitly.  Is there a way to tell the ReadAlarms.vi to monitor every shared variable in a library?  If not, is there another function you can suggest to monitor all of my alarms.
Thanks for your help.
(3,672 Views)
In the older DSC versions, you could assign each tag to a group. Then you could get a list of all of the tags in a group. This would result in an array of tagnames. I don't have 8.0, so I'm not sure if you can use groups with shared variables.
(3,661 Views)
There are no tag groups in LV 8.0 to wire into the Read Alarms function.
PhilP - do you just need to display the alarm information or use that information in other functions?
Robert
(3,650 Views)
Robert,
For now, I just want to display the alarm information.
Phil
(3,646 Views)
In case anyone is interested, I found a solution to my problem.
I passed the name of my variable library (without the .lvlib extension) into Get Shared Variable List.vi.  If fed the output of that function into the ReadAlarms.vi.
phil
(3,641 Views)
