Monitoring 100k/s data and storing using labview
I've created a LabVIEW file, which logs the data (100k/s) from DAQ and storing it in text file.
the method used is producer and consumer queue method.
I have logged the channel (voltage value), upper limit status bit and lower limit status bit in text file
but I need to log only when upper/lower limit status bit is on.
for that I tired case structure but my problem is if I use the dynamic data conversion to array/Boolean, I will lose some data's because the conversion will take some time (the conversion is needed if I need to use the case selector in case structure.)
So, I have not used any conversions, I used only the dynamic data from the DAQ in whole process.
question - Any method to log data only when the upper/lower status bit is on, without using the conversion of the dynamic data at any cost, or any other method.
Thanks in advance for any suggestions!
(663 Views)
If all that you need to do is log data from DAQ, you can use FlexLogger
Santhosh
Soliton Technologies
(630 Views)
  1. Avoid using DAQmx Express VI.
  2. Use TDMS. TDMS can be opened with the TDM Excel Add-In or exported to Excel.
Refer to Producer/Consumer Read Waveform Data and Write to TDMS at Two Different Rates as a starting point.
https://tmesystems.net/
(599 Views)
