Monitor/capture tcp data between a server and client
Hi
I am doing a server/client TCP connection between my laptop and another computer running the server program. With my client program I am able to send commands to the server to which it reacts. However I do not know what the commands are (I just press a button in the client GUI and the command is sent), so my initial thought was that, maybe I was able to monitor/capture the strings/bytes/integers commands, which is send over the TCP/IP. There are only these two computers on the network, so no problem in other traffic there. FYI, they are connected with a wireless peer-to-peer connection.
My problem comes from the manufature of the software making a crabby manual, so really the commands in the manual, which I was supposed to send with my own TCP vi, are just impossible to understand, and don't get me started with their support 🙂
SO, any suggestions if it is possible to capture what is sent over the TCP when I press a button in my client GUI?
LabVIEW 8.6 / 2009 / 2010
Vision Development Module 8.6 / 2009 / 2010
VBAI 3.6 / 2010
(4,009 Views)
Wireshark, http://www.wireshark.org , will capture data off the network and sort/display/categorize.
I don't know how well it will work in a wireless environment, we usually use a wired hub (not switch).
Matt
(4,002 Views)
Hi SCMAJA,
another way is to build your own TCP/IP Server with LabView and receive with it the commands send with your client program.
Mike
(3,999 Views)
Matt
Hi Matt
I have just tried Wireshark, I get a lot of data, so I just have to use a bit of time figuring out what is what, but good program to monitor the LAN connection also wireless. I can monitor all the packages between the client and server. It looks like there is a bunch of data just from keeping the connection active, but again I have to dig a bit deeper before I can say anymore:-)
MikeS81 wrote:
Hi SCMAJA,
Mike
Hi Mike
Yeah I tried that right now using the TCP Communicator - Passive example, unfortunately the connection between the client and server is kept alive using some commands, so the only command I can get to read is the connect command, because the client then refuses the connection because there is no "right" answer/repsonse from the server 😞
edit:
I just got in touch with the support, and got some of the commands to work. I had to make some crazy command with a header first, then size and last my command, all converted from DEC to HEX.. Not easy to figure out 🙂
Message Edited by SCMAJA on 02-08-2008 04:29 PM
VBAI 3.6 / 2010
(3,988 Views)
