Monitor Passed States During VBAI Inspection Execution from LabVIEW
Hello Community,
I hope you're doing well.
I'm working on a project involving Vision Builder AI (VBAI) and LabVIEW, and I need to monitor which states are being executed during the VBAI inspection, i.e., before it ends.
The goal is to track the state transitions of the VBAI state diagram in real time from LabVIEW, so I can react to specific states while the inspection is still running.
What is the best way to achieve this?
  • VBAI ActiveX API?
  • VBAI LabVIEW toolkit?
  • Other options (shared variables, TCP, etc.)?
Thank you in advance for any suggestions or examples!
(666 Views)
Accepted by topic author Salim28
Your questions is very vague. You can accomplish what you want in many different ways. You have your process drawn. Now you need to start building code. What do you know about LabVIEW?
I would start with LabVIEW and a queued state machine. You can find examples of this by searching on line. Look at what others have done and start from there. A queued state machine will give you the ability to do everything that you are asking for. Start some code and come back when you get stuck.
Tim
GHSP
(628 Views)
Thank you very much for your feedback and support, Tim.
I also appreciate your suggestion regarding the use of a queued state machine in LabVIEW. I will start exploring this approach and look into available examples online, as you recommended. I won’t hesitate to reach out if I get stuck.
Thanks again
(604 Views)
Hello everyone,
I'm currently working on a project using Vision Builder AI 2023 that requires 4 cameras, each assigned to an independent inspection job (one script per camera).
My goal is to run 4 inspections in parallel, and I'm trying to do this by opening 4 API connections (VBAI Interface) simultaneously from LabVIEW.
However, when I attempt to open all 4 API connections in parallel, LabVIEW freezes or becomes unresponsive.
So, I have a few questions:
  • Does VBAI 2023 officially support running multiple inspection jobs in parallel, each connected to a separate camera?
  • Is there a known limitation with multiple VBAI API connections from the same LabVIEW application?
  • What are the best practices for handling multi-camera, multi-job inspections in VBAI? Should I use multiple instances of the VBAI Runtime?
Any help or experience sharing would be greatly appreciated. Thanks in advance!
(226 Views)
