Module NI neede for acoustic emission sensor MISTRAS PICO
Hello everyone,
I would like to know which module NI I should put with an acoustic emission sensor like the one from MISTRAS PICO (PICO - 200-750 kHz Lightweight Miniature AE Sensor with Integral Coaxial Cable, by Physical Acoustic...).
It gives an output which spreads on a wide frequency band. Thus it requires acquisition cards with high sampling frequency. Does anyone use such a sensor and which acquisition solution can be advised.
Thank you so much !
Yasmine
(1,217 Views)
Hi Yasmine13579
Based on the emission sensor you choose, use this link to find appropriate c Series Module that is best for your case.
Regards)
________
Best way to thank is to give Kudos / Mark as a solution.
(1,170 Views)
