Modify the VI developed to use a Case Structure instead of a Greater than function to compare the input temperature with the set point.
Hi I am new to VI and could use some urgent help.
The VI Below contains a setpoint, and a temperature. When the temperature exceeds the setpoint the LED will turn on.
I now need to do this, however instead of using the greater then comparison function I am asked to use a case structure.
I have no idea how to do this, and am having trouble connecting the LED and the case Structure
--- I CANT ATTACH MY VI FILE OR A PICTURE, PLEASE EMAIL ME IF NEEDED
ROBBGC@GMAIL.COM
(3,486 Views)
I hate homework assignments that tell you to do something that makes no sense at all...
Well, the case selector can accept numerics.  It will be coerced to an integer to do it.  Also your threshold will not be moveable.
(3,474 Views)
The threshold being my set point? And how would I then be able to wire the led to light up whenever the set point is exceeded by my numeric control(temperature)
(3,462 Views)
The point of the exercise is to get familiar with Case ranges, i'd suppose.
Check "Entering Values for Each Case Structure Subdiagram" in the help.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,419 Views)
