Modicon Modbus communication problem
I am using LabVIEW 8.2 to communicate with modicon PLC via SCP111 rs232 PCMCIA card. When I send a command such as 01 06 00 01 00 01 plus CRC, there is no response from PLC.
I have configured PLC and SCP111 in PL7.  Is there anyone had implemented this communication? Can you give me some suggestions?
帖子被Golden_H在12-06-2007 11:22 PM时编辑过了
(4,089 Views)
Does the PLC supports the ModBus loopback command ? Maybe you can try this.
(4,065 Views)
Download portmon so you can watch both sides of the communication.
http://www.microsoft.com/technet/sysinternals/utilities/portmon.mspx
(4,061 Views)
thank you for your replies. I have solved this problem. My engineer has buyed wrong cable( CD 1030), so I make a CC1030 then jumper 4,5 pins together, 6,8&20 pins togeter too, It is Ok now.
(4,030 Views)
It is always a good idea to check the baud rate and communication settings and wiring then use a simple vi or hyperterminal and send a example string (see the manual for a device specific string) to validate communications over modbus.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(4,020 Views)
