Modern Control Border
Helloteam,
I am working on an applicaiton on TPC where I am  trying to introduce animation. Since I cannot use picture control, i am using the tab control inside a while loop with shift register with different pics on different tabs on my tab control.
I have a submission of my work tommorow and I am unable to remove the border of the tab control which is very annoying. I kinldy request you to reply if you have any idea in this regard.
I am using TPC 2106T
I have also attached the VI for your reference.
Pavan
(4,454 Views)
Hey Pavan,
Even I have a similar application. Can someone please help me in this regard?
Thank you.
Hybrid
(4,434 Views)
If you want the tab invisible, you just have to use the paintbrush tool (View>Tools Palette).
p.s. I made the tab an indicator so you do not have to use that local variable.
(4,418 Views)
Hey Dennis,
Thanks a lot for you reply. On my host computer it is working really well but when I deploy it on TPC 2106T, it does not work as expected. I see a flickering black colour in  the tab control region. Also, the border is also prevelant. I kindly request you to suggest some alternative so that the code would work on the TPC that I am using.
Thanks and regards,
Himadri
(4,400 Views)
Sorry, I don't have the touch panel and I can't imagine what could be causing the tab to be visible at any time at all.
(4,396 Views)
Hey Dennis, Thanks a lot for the reply. Please refer to the attachment. When I deploy to TPC 2016T, all I get is the ON or OFF text and not the picture. Please suggest what can be done. Is there any way in which I can get the animation effect of a rotating wheel on the TPC which has Windows CE Operating System. Regards, Guru
(4,323 Views)
You would have to use a TPC with Windows Embedded OS for this.
Pavan
(4,321 Views)
