Model Interface Toolkit Prbole
Hello
We are working with the modules of Module Interface Toolkit. A simulation file, coming from Simulink, was created and I obtained a .SO. I set up all the parameters according to the instructions NI community recommends making the model run in Labview. The model runs correctly, and the results are correct using Timed Loop. However, after 2 minutes of running continuously, the timed loop starts to desynchronize, and some loops arrive late. Me and my colleagues think that is because the time is so huge so the time that the processor takes to calculate the outputs of the models takes so much. Our question is, can we reset the simulation to reset the time? or What could be the possible reasons the Timed Loop start to take more time to make the calculations even if the parameters of the model have not change?
Thanks for your answers and recomendations
(2,414 Views)
based on the information you provided, I'm afraid I can only advise you to take a look at this help page.
To enable me to help you more effectively, it would be useful if you could share the code, or at least a sufficiently relevant snippet.
Alessia
(2,361 Views)
