Modbus libraries for LabView 6
Is there the Modbus libraries for LabView 6?
Where can i find it?
(3,330 Views)
There are several Modbus libraries for older versions of LV floating around the web and searching Google for "Modbus" and "LabVIEW" should give you some results. I believe one of them was made by Air.
NI made a Modbus library, but that was for 7.1.
I backsaved it for 6.0, so if you want, you can try to open it and see if you can fix it so that it will work.
___________________
Try to take over the world!
(3,325 Views)
Seems like I do have Air's library after all.
___________________
(3,323 Views)
