Modbus device not working with Labview, but works with Python.
For this device with python I just request to read the register 0 and then I get back whatever is there. With labview I only get error. It connects but does not write neither read. I might be missing something very basic. By the way, I have been using Labview for 5 days till now, so I am sure the solution will come 😉.
On the windows firewall I allowed everything regarding labview, etc.
Message 11 of 17
(1,026 Views)
Accepted by topic author henk1000
I have found a quick/temporary solution for my problem. Now just need some implementation. Since the Python code was working well, I just call the script inside Labview and get my numbers.
Still bothered by Labview Modbus library not working but for the moment it's fine.
Message 12 of 17
(1,016 Views)
Like Stockhouse said the ModBus address issue can be really a problem.
Does your device starts at address 0 or 1
In the VI you used a loop. A read every 200msec. Can you device handle this ?
And you should use the 'ModBus master out' (right top output) of the read VI
Kees
Message 13 of 17
(1,002 Views)
Hi Kess,
With the python code, I just read the registers (e.g 60, 61) and I get the value I need in hexadecimal.
In Labview I have tried different numbers for the quantity and initial address, but it did not work. I will try different configurations to see how it works. I am quite new to Labview (Started last Friday 😊) so I suppose I still have to figure out plenty of stuffs. Thankfully the community here is quite active and supportive.
Regarding the scan time of my device, I am not sure if it can handle the 200 ms. I will try longer time and post here the results.
Best,
Henrique
Message 14 of 17
(992 Views)
Post your Python code as well, perhaps that will help us help you debug.
Message 15 of 17
(989 Views)
Sure. Here is the python code for connecting to a modbus device.
from pymodbus.client import ModbusTcpClient
try:
    client = ModbusTcpClient('000.000.0.000', port=000)
    print("Modbus connected")
except ConnectionError as errorcom:
    print("Can not connect to PLC!")
    raise SystemExit from errorcom
v = client.read_holding_registers(60,13).registers
print(v)
client.close()
Message 16 of 17
(967 Views)
I finally managed to connect to two other different devices with Labview !!! 😍
Still do not understand why two devices work with Labview (and python) and the other only with Python.
Message 17 of 17
(962 Views)
