Modbus communication with a breakout box
Hi Guys,
I have a VFD that I want to control via Labview. From the spec sheets of the VFD, it says that I can use "
RS-485 and RS-422 serial communication as a standard". My question is, that I will be only reading or writing to the VFD via Labview and I want the control to be integrated into my main program (I have various other sensors I need to control with just one VI), I can use analog output from my breakout box (an SCC-68) with one wire and recieve and one wire as transmit for serial communication? I am confused on how I should go about doing this as I never dealt with this before.
Thanks in advance!
(2,951 Views)
Do you want to control the VFD using serial or analog?  Modbus serial communication has nothing to do with analog outputs or the SCC-68 breakout box.  You will need either an RS-485/RS-422 serial port on your PC, or a USB to RS-485, or an RS-232 to RS-485 adapter.  RS-485/422 serial communication is either 2 wire or 4 wire.  There is either 2 wires which are a differential pair that handles both transmitting and receiving.  Or 4-wire, 2 pairs where one pair handles transmitting and the other receiving.
(2,941 Views)
