Modbus RTU serial communication error
Hello Everyone,
I am facing an issue while communicating with a system using Modbus RTU protocol.
This system (master) sends 5 set of fixed queries one by one. No access to the master (pre-existing)software.
I have created Modbus slave response to this system as per the protocol in LabVIEW.
There are 3 such identical systems, out of which I was successful in communicating with one system but facing error in other two.
My device is connected to this system via Serial to RS485 converter.
I could read the queries sent by the master which is exact as defined
1) 01 03 00 00 00 51 84 36 H
2) 01 03 00 51 00 51 D5 E7 H
 and so on.
But the response I send to the queries is not reflecting on the Master.( The same which is working with one of the system).
The software in all the three systems are  identical as informed.
If there is any issue in the signal connectivity then I should have not received the queries.
Stuck!!
Can anyone suggest if I am missing anything?
Attaching Screen shot of my slave response
Thanks in Advance.
Message 1 of 8
(10,175 Views)
@Nectar_techabhi wrote:
Hello Everyone,
 and so on.
Stuck!!
Thanks in Advance.
You have three different machines running similar Master Software and Your Slave Module running?
Have you tried available NI Examples to check whether it works fine, Also Compare the Installed Software in all three Machines.
Message 2 of 8
(10,148 Views)
Hello Everyone,
 and so on.
Stuck!!
Thanks in Advance.
Thank you for your prompt response.
Yes three different machines have similar master software running as informed by the proprietor.
Unfortunately, cannot check much at the Master software side. Please suggest
The slave response I have attached is working fine on one of the three system.
I have checked  NI Examples and my slave response is working with MB Serial Example Master.vi.
I have also tried using termination resistor of 120ohm.
Please let me know if anything that I could verify further.
Message 3 of 8
(10,093 Views)
Any Hardware's Involved here? Do you have any Programming Manual available for Master Program?
Message 4 of 8
(10,085 Views)
To clarify, you have three separate systems, each with one master and one slave. NOT three masters and one slave?
Also baud and the id can usually be changed pretty easily on the master. Can you at least verify that all the masters are 9600 and trying to read from ID 1?
Message 5 of 8
(10,071 Views)
The hardware involved is a serial interface card as shown below
The remote terminal unit basically converts the RS485 signals and Ethernet and is connected to Master.
The serial interface card has jumper settings for half duplex and full duplex RS485 and also for termination resistor.
I had doubted the serial interface module, but confused because receiving query from master. If there was issue in hardware i think there should not be any query. Correct me if I am wrong?
I have received a communication protocol for interfacing with master. It has format of master query and for slave response.
I can not share the entire document but will sharing the communication settings and master query and slave response format.
Baud rate: 9600 bps
Parity: No parity
Data bits: 8
Stop Bit: 1
Offset in Holding Register Address : -1
Turn around time: 100 mSec
Master query for reading data of transmit groups
Command
to Read
data of
Slave
Address
Function code
MODBUS
Start
Address Hi
MODBUS
Start
Address Lo
No of
Registers
to read Hi
No of
Registers
to read Lo
CRC
Lo
CRC
Hi
Transmit
Group-G1
01H
03H
00H
00H
00H
51H
84H
36H
Transmit
Group-G2
01H
03H
00H
51H
00H
51H
D5H
E7H
Transmit
Group-G3
01H
03H
00H
A2H
00H
51H
25H
D4H
Transmit
Group-G4
01H
03H
00H
F3H
00H
51H
74H
05H
Transmit
Group-G5
01H
03H
01H
44H
00H
51H
C5H
DFH
Slave response format :
Response format for First tank group G1
Slave Address
1 Byte (Hex)
01H
Function Code
1 Byte(Hex)
03H
Byte Count
1 Byte(Hex)
A2H
Data-1 Hi
Higher Byte (Hex)
00H
Data-1 Lo
Lower Byte (Hex)
00H
Data-2 Hi
Higher Byte (Hex)
01H
Data-2 Lo
Lower Byte (Dec)
12
Data-3 Hi
Higher Byte (Dec)
01
Data-3 Lo
Lower Byte (Hex)
02H
Data-4 Hi
Higher Byte (Hex)
00H
Data-4 Lo
Lower Byte (Hex)
32H
Data-5 Hi
Higher Byte (Hex)
00H
Data-5 Lo
Lower Byte (Hex)
00H
Data-6 Hi
Higher Byte (Hex)
20H
Data-6 Lo
Lower Byte (Hex)
5DH
Data of 2nd UNIT
Data of 16th UNIT
Data-77 Hi
Higher Byte (Hex)
10H
Data-77 Lo
Lower Byte (Dec)
12
Data-78 Hi
Higher Byte (Dec)
16
Data-78 Lo
Lower Byte (Hex)
02H
Data-79 Hi
Higher Byte (Hex)
00H
Data-79 Lo
Lower Byte (Hex)
32H
Data-80 Hi
Higher Byte (Hex)
00H
Data-80 Lo
Lower Byte (Hex)
00H
Data-81 Hi
Higher Byte (Hex)
4CH
Data-81 Lo
Lower Byte (Hex)
59H
CRC Lo
Lower Byte (Hex)
As calculated
CRC Hi
Higher Byte (Hex)
As calculated
Looking forward to your reply.
Message 6 of 8
(10,042 Views)
Yes I have three separate identical systems, each with one master and one slave.
Baud rate is 9600 and ID is 1 confirmed.
Message 7 of 8
(10,039 Views)
Accepted by topic author Nectar_techabhi
I think that's a pretty strong case for "not a software problem"
Check cables.
Message 8 of 8
(10,013 Views)
