Modbus Library master Slave proper example
Is there some kind of a well documented example on how to use the modbus library MB ethernet master slave VIs to read from a modbus TCP connection? I have a Watlow EZ Zone PM controller using Modbus TCP protocol, and i know which registers i want to read to and write from, but I am not so sure how to make the required changes in the master slave VI, specially in the event structure. Could some one help me fix the errors in the VI please? I basically want to read from register 360 and write to register 2160 for now.
(4,930 Views)
