06-19-2008 12:38 PM
06-19-2008 01:00 PM
06-19-2008 02:14 PM
06-19-2008 02:45 PM - edited 06-19-2008 02:46 PM
Peachy wrote:
What do you mean by "bus" inputs and "bus" output?
07-01-2008 01:25 PM
Thank you Raven for your help,
I called a person from Phoenix Contact and he told me to change some parameters inside the module. Now it's working well.
When I want to read: Function code=3, Address=8000, Quantity=1
When I want to write: Function code=6, Address=8001, Quantity=1
Thanx again
Stephanie
07-01-2008 03:14 PM
12-30-2008 05:01 AM
To help anyone with same trouble:
access to the node configuration p.e. web
set off plug&play option
set 0 Process Data Watchdog Timeout
then have a good work
bye,
animalunga
09-14-2018 05:37 AM
Thank you so much. Its work.
