Modbus Communcation using FP-2010
I have to communicate via Modbus over Ethernet and RS232 using the FP-2010. Any suggestions where to start or has this done before?
(3,365 Views)
You can download some modus vi's from http://www.air.nl/nlibrary/library.html
or read our manual: http://www.citengineering.com/english/producten/Modbus.htm
Kind regards,
Jonas Van Otterdijk
CIT
(3,365 Views)
Will the VIs work in real time? It look like it is easy to modify the example to work over TCP/IP.
Thank you for the Help.
(3,365 Views)
Hi Dsmerza,
There is no big difference (as far as I know) between the a labview
program running on your computer and a lv program running on your
fieldpoint. So, I guess it will work...
Good luck,
Jonas
(3,365 Views)
Hi, you can find ModBus Driver for LabVIEW at this URL
http://www.saphir.fr/SAPHIRnet/Admin/home.htm
This driver are fully compatible with LaBVIEW RT (test have been done on FP, PXI and CVS).
I hope it's help you...
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
(3,365 Views)
