Modal error with motion controller PCI-7344 during find reference sequence
I get the following error code when I start a find reference sequence (find encoder index) programmatically:
Error # -70125 occured at FindReference on Axis 1
Possible reasons:
Motion: -70125 (NIMC_wrongModeError)
The function was not executed because it was attempted at an illegal time.
When I do the find reference sequence in MAX, it works fine. But I need I programmatically after the initialization sequence. Does anyone had the same problem?
(2,907 Views)
Could you please post a little bit more informations regarding the board you are using, lv version, ni-motion version and perhaps the code, you have programmed and which is generating the error message?
Thanks.
Evrem
(2,886 Views)
I solved the problem by using the gearing after the find reference sequence where in fact the gearing vi's should be placed.
(2,856 Views)
