MixedGraph control
Hi
I am working on a pplication that controls several valves, flow controller, temperature and pressure. This is working (almost,.. I have problems with a Brooks controller....) but now I am having problems with mixed graph : it does not obey !
I attach here two files (a draft of an action engine), please check that you get the same results... :
You can add a step : on the top panel only pressure and temperature waveforms are shown.
change the action to Clear: the waveform "valve 1" from the bottom goes up ! Why ? I don't want it up ! Is this a bug ?
Also, how to I add a step to mixed graph (I mean not loosing the previous step ?)
thanks for help
(2,856 Views)
Accepted by topic author nitad54448
You should initialize the values into the state "clear", put all of them to 0 for example. See the attached VI in version 2011.
Regards
(2,822 Views)
ok thanks, it works !
(I think NI should add this note in the Help file 🙂 or make a real help topic for mixed graph)
N
(2,816 Views)
