Mixed Signal Graph : plotting of signals in more than one group
I am measuring the output of strain gauges using DAQ device. I don't have any problem in acquiring the data. I have used waveform chart for the representation of strain gauge data (for 1 or more), but it doesn't look so good. So, i have tried mixed signal graph and compare to waveform chart i got better results. Now, instead of showing all signals in one group, i want to show different signal in different group. How can i do that?
thanks..
Best Regards,
JP
(2,151 Views)
Can you attach your code?  I would think that you could just pull the elements you are interested in for each graph by indexing the array.
(2,150 Views)
