Missing video codecs (again?)
Hey all,
   I am trying to write AVI frames to file, and found that I needed to find a better video codec than the one I was using, because I am recording ~hours of data. However after installing a few, I found that IMAQ AVI2 Get codec names.vi is not returning codecs that Windows shows are installed. After searching the forums, I found this, which seemed to suggest that this problem had been fixed awhile ago:
https://forums.ni.com/t5/LabVIEW/Missing-Codecs-in-AVI-Compressor-Comparison-Example/td-p/1403208
To pile on to the issues, the original reason I had to search for a new codec is that I was running into the 2GB AVI size limit (with the default and FFV1 codecs), which I also didn't think was an issue anymore. Anyone else still having these types of issues? Is there something I don't understand about how Windows VCM works?
Running:
LabVIEW 2014 SP1 (64-bit)
Vision Acquisition Software Feb 2015
Vision Development Module 2014 SP1
(3,684 Views)
Hi pdahl,
I found a few resouces that may be helpful for you in case you haven't come across them.
AVI Codec Support with AVI2 in NI Vision Products:
https://www.ni.com/en/support/documentation/supplemental/21/avi-codec-support-with-avi2-in-ni-vision...
LabVIEW Vision won't create large AVI File:
https://forums.ni.com/t5/Machine-Vision/LabVIEW-Vision-won-t-create-large-AVI-File/td-p/2570713
I hope these help!
- Kale
(3,640 Views)
